Activity › Forums › Adobe Premiere Pro › Audio data rate option missing in CS6?
  • Audio data rate option missing in CS6?
    Posted by Jason Wiltse on July 16, 2012 at 2:14 pm
    I am exporting a :30 commercial that I cut entirely in Adobe Premiere Pro CS6. When exporting I select the tab for Audio. I am able to choose the codec (AAC) and the Basic Audio Sample Rate (44.1) and Channel (Stereo). The drop down does not include anything else. In previous versions of Premiere I have been able to set the data rate. Is this a glitch or will I no longer be able to increase my audio data rate in Premiere Pro CS6?
    Gus Wiltse
    Posi Creative Production & Design
    Minneapolis, MN
    Angelo Lorenzo replied 14 years, 2 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    July 16, 2012 at 5:00 pm
    Are you exporting MOV? As far as I can remember, you were never able to set the audio bitrate within Premiere, at least not the last few versions.
    As a simple solution you could export as .h264 which allows greater control, then rewrap the file as an MOV with something like https://www.squared5.com/
    At that point, the streams aren’t recompressed, they’re just taken out of an MPEG container and put in an MOV container.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
