Activity Forums VEGAS Pro Audio Cuts Out in Rendered Video (Sony Vegas)
  • Audio Cuts Out in Rendered Video (Sony Vegas)
    Posted by David Halpert on February 21, 2011 at 6:41 pm
    I’m having a unique problem with Sony Vegas that I’m hoping you guys can help solve.
    My plan was to create a video game commentary where I record myself with a green screen in the background. While this is happening I’m using a Toshiba DVD recorder to record the gameplay as I’m playing. My plan was to finalize the DVD, rip it to my laptop and place the gameplay footage in the background on the green screen, so you can see myself and the gameplay footage playing at the same time.
    This worked fine. Each video is roughly 45 minutes long. However, after I render the video the audio works fine until about 10 minutes into the video then all of a sudden both the gameplay audio and my commentary audio cut out at the same time. And it stays that way for the rest of the video. This has happened on two separate computers with two separate movies. However, in the editing suite the audio plays fine.
    I’m placing the render settings below that I normally use in the hopes that someone could give me any insights into why this is happening. I currently use Vegas Movie Studio Platinum 9.0. I’ll take any suggestions no matter how remote. This happens with both wmv formats and avi formats.
    Rendering Settings:
    Windows Media Video V11 (.wmv)
    Audio:
    Mode: CBR
    Format: Windows Media Audio 9.2
    Attributes: 64 kbps, 44 kHz, stereo (A/V) CBR
    Video:
    Mode: Quality VBR
    Format: Windows Media Video 9
    Image Size: High Definition (1080×720)
    Pixel Aspect Ratio: 1.000 (Square)
    Frame Rate 30.000
    Seconds per keyframe: 3
    Bit Rate: ISDN: 500k
    Matt Crowley replied 15 years, 6 months ago 3 Members · 3 Replies
  • Nigel O’neill
    February 22, 2011 at 2:41 am
    You haven’t accidentally muted the audio events by any chance (they show up as shaded sections on the time line) or dragged the gain from 100% to zero on the audio event?
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • David Halpert
    February 22, 2011 at 3:32 pm
    I managed to solve the problem yesterday. Instead of ripping the DVD footage as an AVI I ripped it as a WMV and the movie rendered fine.
  • Matt Crowley
    February 22, 2011 at 5:40 pm
    You should be able to import the DVD footage directly in Vegas. On the Project menu, click Import DVD Camcorder Disc. You just choose the disc to import from, and where to put the extracted files. You’ll then have one or more MPG files that you can edit as desired.
