Activity Forums Blackmagic Design Audio crackle on analogue out of MultibridgeSD
  • Audio crackle on analogue out of MultibridgeSD
    Posted by Poatley on October 13, 2005 at 2:18 am
    I’ve been trying to lay off a project to BetaSP via the MultibridgeSD and I’m having real problems with audio. I’m assuming its a sync issue, but not sure how best to resolve it? I’m coming out of my FCP suite SDI into the Multibridge and then component and balanced audio into the Beta. Try as i might the audio has crackles and pops every minute or so. I’ve seen this before with D>A’s, but not sure why the Multibridge is suffering as i was under the impression it locked to the incoming SDI+embedded feed?
    Many thanks in advance.
    Luke Maslen replied 20 years, 11 months ago 2 Members · 1 Reply
  • Luke Maslen
    October 14, 2005 at 5:00 am
    Is there some other location in which you can test the Multibridge SD? Even another room in the same facility with different harware and preferably connected to a different power supply? This will help to establish whether the problem continues with the Multibridge SD or is only occuring in a particular setup. That would help us to diagnose the problem.
    Regards,
    Luke Maslen
    Blackmagic Design
