Activity › Forums › Panasonic Cameras › Audio Crackle added to 1400 during Record to Tape
  • Audio Crackle added to 1400 during Record to Tape
    Posted by Walter Biscardi on March 5, 2007 at 4:25 pm
    Hi all,
    We’ve run into an issue with our brand new 1400 deck whereby a high end crackle is being added to our audio during Master to Tape when using Firewire Input. In fact it can be heard when simply monitoring the audio through the deck.
    It sounds like sizzling bacon or crinkling cellophane. Our Panasonic dealer just brought another 1400 to the shop and we heard the exact same thing on that deck.
    HD-SDI is clean, but Firewire is adding the crackle. This is unique to this deck as we laid off about 40 HD Broadcast masters on our old 1200A with zero audio issues.
    Anyone else have a 1400 they can check and see if you’re hearing the same thing? I honestly can’t hear it as I have a hearing loss in both ears, but so far three technicians at a dub house, my assistant editor, my wife (audio designer) and our VAR have heard this issue.
    We can’t lay back to tape via HD-SDI because that will add another layer of compression to the masters. Right now we’re probably going to rent an HDCAM deck and just lay off straight to that through our Kona.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Walter Biscardi replied 19 years, 6 months ago 1 Member · 3 Replies
  • Walter Biscardi
    March 5, 2007 at 11:53 pm
    Have heard from Panasonic that they are looking in to this issue and will hopefully be back in touch with me within a week’s time.
  • Walter Biscardi
    March 19, 2007 at 8:39 pm
    According to the engineers working on my deck at Panasonic, the issue is limited to 720p record back to the 1400. No fix yet, but they are still working on it.
  • Walter Biscardi
    March 21, 2007 at 2:29 pm
    Upon further testing and review, it’s the Apple Mac Pro that’s adding the audio crackle. Our audio engineer feels it’s a word clock issue that is causing this to happen. Via HD-SDI, we don’t get the issue but the audio is passing through the Kona 3 at that point.
    Will update if we can find a way to solve this.
