Activity › Forums › Adobe Premiere Pro › Audio Clipping
  • Audio Clipping
    Posted by Roman Karpinski on September 24, 2009 at 11:32 am
    I am encountering problems on my Adobe Premier CS4 and Blackmagic when capturing.
    After capture when playback in Premier source window the file has clipping all the way through in the audio track and can be seen in the wave form of the file.
    Can anyone help ?
    Roman
    Jeff Brown replied 17 years ago 2 Members · 1 Reply
  • Jeff Brown
    September 24, 2009 at 4:28 pm
    What is the source you are capturing? Most likely, you have too hot a signal going in. (sorry if that is blatantly obvious)
    -jeff
