Activity › Forums › Avid Media Composer › Audio clipping across match-frame edits?
  • Audio clipping across match-frame edits?
    Posted by Christopher Travis on August 1, 2016 at 11:55 am
    Hello there,
    I’ve been working in Avid for a few years and I think this is the first time I’ve come across this.
    I’m an offline editor, and when I’m cutting, I do my rough audio mixing by adding match frame edits on the music tracks, dipping them and adding cross-fades across those edits.This has worked just fine for me for years, and I find it much quicker than adding and manipulating keyframes.
    However on my current project I’m noticing that I’m having issues. Across a lot of these edits I’m hearing what sound like very slight skips, or audio pops, as if the audio either side of the edit have slipped back or forward a frame even though it’s a match frame edit.
    I’m working in MC v8.4.2 on windows. Anyone got any ideas? I’d rather not have to go back and re-do all this mixing with keyframes if I can avoid it.
    Chris
    Job Ter burg replied 10 years, 1 month ago 3 Members · 5 Replies
  • Glenn Sakatch
    August 1, 2016 at 3:13 pm
    I, like you have used this technique for a long time. (i started on Avid in 95, and that was how i learnt to use audio on the timeline…still do it to this day)
    I am now running box on 8.5, one on 8.6 and haven’t seen an issue.
    Are you hearing the pop after you add a dissolve?
    I will occasionally hear a pop on an audio edit if you are not at a 0 point crossing in the audio, but usually a 1 frame dissolve will fix that.
    do you hear a pop if you do an add edit, but don’t adjust levels on either side?
    Glenn
  • Christopher Travis
    August 3, 2016 at 1:23 pm
    Hi Glenn,
    Thanks for your response. I don’t get any pops or jumps when the levels are the same on both sides of the cut. It’s only noticeable when I have a cut, with different levels on each side, and a crossfade across the cut.
  • Glenn Sakatch
    August 3, 2016 at 2:00 pm
    weird…I am not seeing that.
    Are you linking to media, or is it avid created media. Perhaps just a lag from linked media?
    Glenn
    August 3, 2016 at 2:32 pm
    Nope, these are audio files that have been imported into the Avid. Just to confirm, I tried adding a match frame edit on a music track that had no percussion, just a droney soundscape, and there is definitely, very audible clipping at the start and end of the cross fade. If i take the crossfade off, I can still hear clipping, and most strangely, if I set the audio levels on the track back to the same levels, I STILL hear clipping across the cut.
    Any thoughts?
  • Job Ter burg
    August 10, 2016 at 7:08 am
    Did you render them?
