Activity Forums Blackmagic Design audio clicks during playback
  • audio clicks during playback
    Posted by Jaap Verdenius on September 17, 2012 at 6:59 pm
    I hear audio clicks during playback in FCP – after I moved to another place in the timeline.
    I don’t hear them when I use other outputs, so I guess it must be a Decklink issue.
    What could be the cause?
    OS 10.7.4
    FCP 7.0.3
    MacPro Mid2010 Dual Quad 16GB
    latest BM drivers
    Andreas Wojtaschek replied 13 years, 11 months ago 3 Members · 3 Replies
  • Chris Pearse
    September 18, 2012 at 4:46 am
    Hi Jaap,
    I haven’t come across any problems like this with Final Cut Pro before. I would suggest trying with different footage and settings and see if the problem remains. If it does, it would be worth checking if reverting to older drivers makes any difference.
    If you’re then still seeing the same problems please contact support since they will be better able to to try and reproduce the issue and suggest what could be causing the problem. You can contact support using the numbers on the page here, or using the support request form on the product’s support page.
    Chris Pearse
    Blackmagic Design
  • Jaap Verdenius
    September 18, 2012 at 2:29 pm
    Hi Chris,
    I changed to another system disk (an HD instead of an SSD) and now the problem vanished, so that makes it not a Decklink issue, unless there is a reason why the Decklink would behave differently with a SSD instead of a HD.
    Could a SSD be too fast for some action related to AV output?
    (OK, I know this sounds ridiculous but… well, you never know)
    Jaap
  • Andreas Wojtaschek
    September 18, 2012 at 8:01 pm
    A SSD can be so fast that it blocks the whole cpu bus capacity of your machine. That could cause some problems when the decklink card requests some packets over that bus.
    Cheers
    Andreas
    Entertainment Producer IHK
    mindandvision
