Activity Forums Adobe Premiere Pro Audio click at end of track in aaf export
  • Audio click at end of track in aaf export
    Posted by Olivier Aubut on February 8, 2016 at 4:22 pm
    The audio engineer mixing our shows is telling us that every clip, when dragged out to the end, has an audible click on the last frame/samples. I’m not hearing them on the Premiere timeline.
    This is more problematic on the music tracks, since I usually don’t use an out point on those clips.
    I’m creating an aaf from premiere 9.0 and he’s mixing in pro tools.
    Anybody aware of this problem or know a workaround?
    Olivier
    Olivier Aubut replied 10 years, 7 months ago 2 Members · 2 Replies
  • Vince Becquiot
    February 8, 2016 at 6:09 pm
    I have not heard of it. You could try putting a 2-3 frame audio fade at the end of the clip and send a test clip. That solved the click issue when it happened in my timelines..
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Olivier Aubut
    February 8, 2016 at 6:23 pm
    Thanks Vince
    Sure, I can do that but that’s not really fixing the problem. I could also make sure to add an out point to my audio clip.
    The Audio guy is saying that the click is only a couple samples long and not really audible while mixing but ounce exported, that click is loud and clear.
    It’s as if Premiere is trying to compensate the missing samples and filling them with noise. (Don’t know if that makes sense)
    I guess I’ll file a bug report and hope this gets fixed soon…
    Olivier
