Activity Forums JVC Cameras Audio Channels on the JVC GY-HM700
  • Audio Channels on the JVC GY-HM700
    Posted by Michael Lavis on March 30, 2011 at 8:45 am
    Hi
    I have just recently purchased a JVC GY-HM700 and am really enjoying using it and its quick workflow. But i have noticed an audio problem in FCP (probably a setting i need to change).
    Il start at the beginning, I have two mics usually plugged straight into the camera, a top mic plugged into input 1 (set to auto) and then a second boom mic plugged into input 2 (set to manual). I also have the CH-2 Input set to Input2.
    When i import the clips into my timeline in FCP i get two audio tracks which is great but when i come to select an individual track it wont let me and just selects both.
    How can i set up the camera or FCP to allow me to say select the second audio track recorded from the boom and not the camera mic?
    I hope you can help.
    Many thanks
    Mike
    Charles Wannop replied 15 years, 5 months ago 2 Members · 6 Replies
  • Charles Wannop
    March 30, 2011 at 9:02 am
    It sounds like a Final Cut trick… click on the audio tracks then deselect “Stereo Pair” under the Modify menu. Tracks should now be separated.
    Charles.
  • Michael Lavis
    March 30, 2011 at 10:17 am
    U Beauty, cheers mate. Its worked.
    Many thanks
    Mike
  • Michael Lavis
    March 30, 2011 at 10:22 am
    But, just another quick one. This is obviously gonna be a slight hassle if i have to do this from now on, is there a way to set up FCP so when i input the clips this setting is already activated. Also noticing that the pan is always set to either left or right and im having to adjust that as well????
    mike
  • Charles Wannop
    March 30, 2011 at 10:53 am
    Yeah I meant to mention the PAN setting 🙂
    I might pass this over the FCP experts – it looks like the clip’s audio settings take precedence over the sequence sequence pre-set.
    Funny thing is, my KiPro does the opposite (leaves the clips with dual mono centre panned) and it drives me nuts 🙂 But in the long run it’s a pretty small inconvenience compared with having to trans-code or log and transfer.
    c
  • Michael Lavis
    March 30, 2011 at 1:14 pm
    Thanks for your help, that makes sense. Will you pass it on for me, or should i re-post this in the fcp forum?
    Mike
  • Charles Wannop
    April 1, 2011 at 9:17 am
    Go for it 🙂
    Charles.
