Activity › Forums › Panasonic Cameras › Audio Channel 1
Audio Channel 1
Posted by Adrian anthony Vasquez salteiro on May 27, 2007 at 8:08 pmWhen I switch the CH1 SELECT switch to INT (L), the audio bar of CH1 in the LCD Screen does not show any activity of audio recording… What could be wrong?
Adrian
Barry Green replied 19 years, 4 months ago 3 Members · 3 Replies -
Noah Kadner
May 28, 2007 at 2:48 amIs the volume knob turned up- what do you hear on your headphones?
Noah
Unlock the secrets of the DVX100 and Final Cut Pro!
https://www.callboxlive.com -
May 28, 2007 at 2:57 amThe volume dial is set in the middle. In my headphones I hear sound only in the Right side. The camera is new, I have’nt dropped it or anything like that. And I remember it was working just fine…
I dont have guarantee on the camera here… I bought the camera in USA And I’m in Panama now. Hope is nothing extremely bad nor expensive.
Barry Green
May 28, 2007 at 8:08 pmLook at the line/mic switch on the front of the camera, and if you have a microphone plugged into channel one, make sure that the line/mic switch is set to mic.
Also, if it’s a condensor microphone that needs phantom power, make sure the phantom power switch for channel 1 is set to “on”.
Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
