Activity › Forums › Creative Community Conversations › Audio Capabilities
  • Paul Dickin
    June 30, 2011 at 9:48 am
    Hi
    Here someone who’s commented on the audio features:
    https://danrubottom.com/2011/06/what-apple-did-get-right-in-final-cut-pro-x-part-1/
  • Paul Figgiani
    June 30, 2011 at 10:25 am
    One thing regarding the Audio tools. … the new stuff is nice. However there are a few key issues that in my view need to be addressed:
    FCPX needs an embedded waveform editor, just like Soundtrack Pro. At this point it is impossible to make accurate edits, especially on dialog clips. You simply cannot do this in a timeline of an NLE. If this is not in the plan, well then we need a smooth way to get audio clips out and back into FCPX by way of something like “Open in Editor.” This way I can use something like Audition or Peak, save – and send back to FCP. At this point you can control + click a clip and “Show in Finder” from within FCPX. Open the clip in a secondary app., save it … and then re-import. It’s not very efficient..
    Lastly the cartoonish looking waveforms simply will not work in a professional environment. There is not enough transient detail that is often necessary for editing and various aspects of timing.
    Lot’s of potential, here. I’m sure apple is on it.
    -paul.
  • Nick Toth
    June 30, 2011 at 1:06 pm
    Sorry – I respectfully disagree with this assessment. Using a combination of zooming in to the audio waveform (you know you can show just the waveform correct?) and the skimmer with audio scrubbing enabled you can get more accurate than in previous versions of FCP. Give it a try.
    NT
  • Chris Kenny
    June 30, 2011 at 1:58 pm
    Since this option is fairly non-obvious:
    At that point you can use the clip height control to make the waveforms nice and tall:
    Digital Workflow/Colorist, Nice Dissolve.
    You should follow me on Twitter here. Or read our blog.
  • Paul Figgiani
    June 30, 2011 at 2:00 pm
    I never said the features in FCPX are not better than in FCP 7. If what’s there works for you, cool.
    -paul.
  • Paul Figgiani
    June 30, 2011 at 2:18 pm
    For precise editing I need to see this type of detail, especially when editing dialog. Typically this type of stuff is not done in the timeline of an NLE. What I propose is a more precise editor or an efficient way to send audio out and in after editing/processing.
    -paul.
