Activity Forums Apple Final Cut Pro Legacy audio bug in FCP 4.5
  • audio bug in FCP 4.5
    Posted by Skaren72 on December 11, 2005 at 3:12 am
    Suddenly all these clips in my sequence are coming off muffled and only playing eft channel. When I resert pan to 0 the sound comes back to normal, but that means I have to manually change each individual clips. Does anybow know if this could be a simple corruption problem or if it is a FCP 4.5 bug? How can I fix this globally so I dont have to waste the time fixing each individual sequence? I have been exchanging xml files with another editor and I am wondering if somehow this constant exchange is contributing to the problem. Any pointer asap to: ks2037@columbia.edu. Many Thanks!
    Skaren72 replied 20 years, 9 months ago 2 Members · 2 Replies
  • Nick Meyers
    December 11, 2005 at 11:50 am
    i;’d say it’s definitely a by-product of the XML interchange.
    you can globally change all the clips if they are in a TIMELINE.
    select all, and Control . (full stop)
    Control , = Pan Left
    Control . = Pan Centre
    Control / = Pan Right
    the same controls will work in the viewer,
    and even though it;s a one-at-a-time situation,
    it;s still quicker than re-setting the slider, or tabbing to the pan filed and typing in 0.
    cheers,
    nick
  • Skaren72
    December 11, 2005 at 3:34 pm
    What a life saver! Thanks Nick.
