Activity Forums VEGAS Pro audio bleeps and glitches with wave hammer
  • audio bleeps and glitches with wave hammer
    Posted by Barend Jasper on September 12, 2005 at 10:25 am
    ladies, gentlemen,
    Sorry if the following has been addressed recently.
    The thing is that I’m having some serious problems with the Wave Hammer Compressor. When activating it on the master bus, I get unwanted soft audio bleeps and glitches. When I switch of the compressor, the glitches are gone. I however want to continue using the compressor. Any ideas? Am I doing something wrong here?
    Thanks a million in advance,
    Barend Jasper
    James_j replied 21 years ago 3 Members · 5 Replies
  • Dirk
    September 12, 2005 at 2:05 pm
    That’s a well known issue, when you last updated Sound Forge, or perhaps Vegas, wave hammer reverted back to demo mode, bleeps. You can check their forums for the solution. It entails removing old directories and some registry entries.
    Good luck,
    Dirk
  • Barend Jasper
    September 12, 2005 at 2:15 pm
    Thanks Dirk, I’ll check it out.
    Barend Jasper
  • James_j
    September 14, 2005 at 4:10 am
    FWIW, we always use Wavehammer on *tracks* rather than the Master bus for this reason.
  • Barend Jasper
    September 15, 2005 at 12:41 pm
    Yes, one can put compressors on each track. But I like to compress the final master as well. What’s wrong with that if I may ask?
    Barend Jasper
  • James_j
    September 15, 2005 at 1:44 pm
    Like you said, and I confirmed, it just doesn’t seem to work as well. I can’t be more specific because I haven’t tried it in ages. Maybe I was getting the same thing you are. I dunno, but since it’s not really necessary, I just don’t do it.
