Audio becomes quieter in After Effects after importing it via Dynamic Link
Whenever I use Dynamic Link between Premiere Pro and After Effects, I end up having my audio sound much quieter in After Effects compared to how it sounded in Premiere Pro. I presume this has something to do with the Stereo Mixer effects, because when I manually disable these effects, the audio sounds just the same as it did in Premiere Pro.
I attached the screenshots.
Is there any way to fix this?
Thank you for your time and help 😀
