Activity Forums Apple Final Cut Pro Legacy audio balancing in final cut pro
  • audio balancing in final cut pro
    Posted by Rajarshi Banerjee on December 13, 2008 at 6:53 pm
    hi im Raj from india
    i am documentary film editor, but few months back i joined endemol india as online editor, here i work only on realty type show, now mostly i get little time to edit but thats fun the pain part is audio balance coz i had to do it so manually that its boring time taking and not a thankful job at least in my studio, i m just wondering if there is any way of scripting or sort of macro or effect that i can select an audio track and just apply to it defining that no audio will be below -18db and above -12db. and it will be roughly done atleast cut the peak and dip,without ditoring or modifying audio quality
    regard
    raj
    Rajarshi Banerjee replied 17 years, 8 months ago 2 Members · 2 Replies
  • Michael Gissing
    December 14, 2008 at 12:02 am
    That’s a bit like asking if there is a script or macro to edit so that you can go home early and let the machine select shots and make them a certain length.
    Audio balancing is just as much an art as editing so no, there isn’t an automatic thingy to mix audio. It is a creative manual task, just like editing.
  • Rajarshi Banerjee
    December 17, 2008 at 8:13 am
    thankx for your post,
    i knew it i won’t be that lucky to go home early, but there must be some filter to cut the extra db. above 12. without disturbing the quality.
    if so please let me know.
    regard
    raj
