Audio and Video out of sync
First of all, I am running FCP 6.0.6 on 2009 iMacs with 3.06ghz Intel core 2 Duos and 4gb of ram.
I am struggling with a new problem that I haven’t seen before, after logging and capturing my students audio and video is out of sync. It is usually off by about 2-3 seconds and it is consistent from the first frame of video to the last, not a “drift” problem as I have read about from mismatched bit rates.
All of this footage is shot on new DV tapes with canon ZR960 camcorders in my classroom. The footage is captured using the capture now setting. It doesn’t happen on all of the computers in my lab, and it seems pretty random when and where it happens.
I have tried trashing the preferences on the computers that are having issues, which hasn’t helped.
I tried logging and capturing with different cameras, no luck.
If I import into iMovie using the same tape, camera and computer that was out of sync in FCP it syncs up perfectly which leads me to believe I can rule out computer hardware issues, camera problems, or bad tapes.
Are there some settings in FCP that could have accidentally gotten changed by one of my students that would cause this to happen, or something else I should check out?
