Activity › Forums › Adobe After Effects › audio
audio
Posted by Tiago Veloso on November 2, 2011 at 1:06 amHello.
I am trying to work with AE and sounds.
But the only way that I’ve found to that is the RAM rendering…
How can I work with video if I don’t listen anything to cut where I should cut.
thanks
TiagoTudor “ted” jelescu replied 14 years, 10 months ago 2 Members · 3 Replies -
Tudor “ted” jelescu
November 2, 2011 at 9:54 amFirst thing about AE- it’s not designed to work with audio or edit. For that use Premiere Pro or FCP.
If you need to play the audio and set markers, you can just hit the “.” key from the numeric pad for playback and the “*” key from the num pad for setting markers.Tudor “Ted” Jelescu
Senior VFX Artist -
Tiago Veloso
November 2, 2011 at 10:24 pmThank you.
So… First I have to make all the effects with After Effects.
And, then export the movie to Premiere.
Right?Is necessary to make the movie in After Effects to export it (save as .mov or .avi)? Or is there any way to export it directly to Premiere?
Thank you again.
Tudor “ted” jelescu
November 3, 2011 at 8:53 amhttps://tv.adobe.com/watch/learn-after-effects-cs5/streamlining-your-workflow-with-dynamic-link
https://www.youtube.com/watch?v=Nzh7lY1s4Dk
Tudor “Ted” Jelescu
Senior VFX ArtistSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
