Activity Forums Avid Media Composer Audi Pull down in AVID
  • Audi Pull down in AVID
    Posted by Rachel Shore on July 28, 2011 at 9:18 am
    I was given 24p footage from both the 5D and 7D. I was also given sound recorded at 29.97 fps. Is there a plug-in in MC5 that I can use to pull down the sound so it stays in sync with the picture?
    Michael Phillips replied 15 years, 2 months ago 2 Members · 1 Reply
  • Michael Phillips
    July 28, 2011 at 4:57 pm
    I suspect your Canon files are really 23.976? If so, there is no need to pulldown audio – it will play in sync since 48kHz is 48kHz. When importing the audio, and if BWF, you will be prompted for frame rate of file. Select 29.97.
    If your video files are truly 24.000 and you are in a 23.976 project, and they are being pulled down, then it is a different issue.
    Please confirm.
    Michael
    Michael Phillips
