Activity Forums Apple Final Cut Pro AU Eval Bug in FCPX since Ventura 13.3.1 update
  • AU Eval Bug in FCPX since Ventura 13.3.1 update
    Posted by Ben Balser on April 12, 2023 at 11:09 pm
    Since updating to Ventura 13.3.1 I can’t launch FCPX. When it tries, it hangs up during evaluating AU plugins. Sometimes it finally crashes, sometimes it just hangs forever, requiring a force quit.
    No new plugins have been added in quite some time, and everything ran fine before the 13.3.1 update.
    Has anyone else seen this? Any solutions? Unlike LPX, FCPX doesn’t allow you to temporarily disable AU plugins.
    Ben Balser replied 3 years, 4 months ago 3 Members · 4 Replies
  • Cat Peterson
    April 13, 2023 at 4:21 am
    Same problem.
  • Robert Olding
    April 13, 2023 at 3:08 pm
    Most of the recent crashes and hangs are related specifically to the discontinued Accusonus ERA audio plugins. This video from Matthew O’Brien explains the process of making sure you find all the pertinent files to remove the plugins and fix the situation.
  • Ben Balser
    April 15, 2023 at 2:43 am
    Found the solution. I had recently installed Screens 4. Uninstalled it, and everything is now fine. But yes, there is an AU Validation issue. Mine hung up on various different AudioUnits, including Apple’s own SoundIsolation AU. I really don’t think it’s specific AUs, it’s something buggy in Ventura 13.3.1.
  • Ben Balser
    April 21, 2023 at 1:55 pm
    P.S. I also found I had to remove the recently installed Screens4 app before FCP started working again.
