Activity Forums Apple Final Cut Pro Legacy Attention all Boris FX 8 and FCP5.1.2 users
  • Attention all Boris FX 8 and FCP5.1.2 users
    Posted by Kim Rowley on November 30, 2006 at 9:25 am
    I know there have been recent issues concerning FCP and transitions in Boris FX and RED. I just got a clear answer back from the Boris support team that sheads some light on instant crashes I was having with Boris FX8 and FCP 5.1.2. Just thought I’d post it here incase it can be useful to others and save you some time. I tried the workaround -a bit tedious- but it works.
    From Boris support:
    In upgrading from FCP 5.1.1 to 5.1.2, Apple
    adjusted the code in a way that adds, in a sense, a roadblock for our
    transitions, which is causing FCP to crash (FCP goes idle while RED
    is active, but it’s not able to go fully active, so the entire system
    goes down).
    However, filters and generators do still work, and because of this
    problem, we have made a .pdf file that will illustrate a
    work-around. What this illustrates is how to adjust the timeline
    clips and use the Media Well’s to create a transition using a
    filter. I have it attached and hope that it will help you with this
    for the time being.
    PDF file – copy and pasted here:
    Setup the video tracks in order to
    create an A/B transition where the
    incoming video (A) is above the
    outgoing video (B) and the
    overlap is the desired length of
    the transition.
    Add cuts to the tracks in
    order to isolate the area the
    transition will be.
    Apply the Boris RED 4.0 filter to the
    trimmed clip in V2 and double-click the
    clip to load it into the Viewer window.
    Select the Filters tab and you should
    see the Boris RED 4.0 filter, drag the
    trimmed clip from V1 into the well
    labeled Video 2 in the Viewer widow.
    Now when you enter Boris RED V1
    will be the incoming media and V2 will
    be the outgoing media just as it was in
    the older transition. All of the prebuilt
    transitions our Library should work
    correctly with the setup as well.
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.03, OS X10.4.3
    Nosweatjonny replied 19 years, 9 months ago 3 Members · 2 Replies
  • Walter Biscardi
    November 30, 2006 at 1:12 pm
    Boris is having all sorts of problems with FCP 5.1.2. The BCC 4 plugs don’t work correctly on an Intel Mac right now which I’ve documented here and in the Boris Forum. They actually cause the FCP Boris Title 3D to crash the system.
    At least they’re starting to get the workarounds in place. For now I have to keep the BCC 4 plugs out of FCP unless I need to use one, then I put them all back, render out my effect, and pull them back out. They hope to have an engineered fix soon.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Nosweatjonny
    December 5, 2006 at 6:40 am
    I have tried this, and the person from Boris to whom I spoke with was very helpful. Unfortunately, it only worked for about a half a day, then anytime I tried to open the clip to which the filter was applied, or even just clicked on that clip, FCP just began to crash…..over, over, and over again. So does anyone have any idea what I may be doing wrong? Or are there still bugs to be worked out on Boris’ end?
    I am using FCP 5.1.2, on mac os x tiger, G5, quad processor. I used Boris FX 8.0, downloaded the software patch, deleted the old cache files, lauched w/ caps lock….etc., and it only worked for a while.
