Activity › Forums › Adobe After Effects Expressions › Attemping to disable all expressions in selected comp using Extendscript
  • Attemping to disable all expressions in selected comp using Extendscript
    Posted by Keenan Parry on September 26, 2019 at 10:27 pm
    Hi there. I’m trying to write a little script that disable every single expression in every layer of a selected comp. I’m having trouble finding a method or function that is able to look at every property, no matter what it is, and disable it. I’ve gotten as far as being able to disable a selected property, but it would be great to have a script that could disable expressions on a mass scale by itself. Any help appreciated, thank you!
    var activeComp = app.project.activeItem;
    app.beginUndoGroup('Disable Expressions');
    for(var i = 0; i < activeComp.selectedProperties.length; i++) {
    var property = activeComp.selectedProperties[i];
    if(property.expressionEnabled === true) {
    property.expressionEnabled = false;
    }else{
    app.endUndoGroup();
    Oleg Pirogov replied 6 years, 11 months ago 2 Members · 1 Reply
  • Oleg Pirogov
    October 29, 2019 at 3:36 pm
    This should do it:
    function disapbleExpressionsInPropertyGroup(propertyGroup){
    var propertiesAdded = false;
    for (var i=1; i<=propertyGroup.numProperties; i++){
    var currentProperty = propertyGroup.property(i);
    if (currentProperty.propertyType == PropertyType.PROPERTY){
    try{
    currentProperty.expressionEnabled = false;
    catch(err){
    else{
    disapbleExpressionsInPropertyGroup(currentProperty);
    return propertiesAdded;
    function main(){
    var activeItem = app.project.activeItem;
    if (activeItem instanceof CompItem){
    for (var i=1; i<=activeItem.layers.length; i++){
    disapbleExpressionsInPropertyGroup(activeItem.layers[i]);
    else{
    alert("No composiotion is active");
    main();
