Activity › Forums › Adobe After Effects Expressions › Attatching a mask point to another layers position?
  • Attatching a mask point to another layers position?
    Posted by Göran Thorén on October 20, 2013 at 3:38 pm
    Hi all!
    Is this possible at all?
    What I’m trying to achieve is to use the stroke effect and have the end of the stoke follow the edge of another layer.
    Thank’s for any input on this!
    /Husse
    Todd Kopriva replied 12 years, 11 months ago 3 Members · 2 Replies
  • William Marler
    October 20, 2013 at 8:23 pm
    Hi Göran,
    If the mask is simply a line that you want the start and end moving with another layer, then go to Effect>Generate>Beam, and pickwhip the start or end point to your other layer.
    If it’s a mask you need because it is a complex shape, I am not sure, but I will keep looking.
    Hope this helps!
  • Todd Kopriva
    October 21, 2013 at 7:54 pm
    Christopher Green has some handy scripts for attaching mask vertices to things:
    https://www.crgreen.com/aescripts/
    After Effects team blog
