Activity Forums Maxon Cinema 4D attaching objects to a deforming mesh
  • attaching objects to a deforming mesh
    Posted by Neil Sanderson on February 8, 2011 at 2:39 am
    does anyone know how to attach objects to a deforming mesh? I’m using morph targets to animate an inflating surface but need a separate object positioned on the surface to move with the deformation. any help would be awesome!
    André Irniger replied 15 years, 7 months ago 2 Members · 1 Reply
  • André Irniger
    February 8, 2011 at 5:27 pm
    Hy Neil,
    this is a solution which costs a bit, but it does exactly what you want and … a lot more. The very first component described in the (german) tutorial here shows you how it works.
    https://www.remotion4d.net/tutorials/GeoTools_Tut1/geotools1.html
    If this is too oversized, maybe check-out xsPolyInstance:
    https://www.xsyann.com/
    xsPolyInstance should be able to get the job done too. I didn’t use it myself but I think the name already reveals what it will do.
    Cheers,
    André
