Activity Forums Adobe After Effects Expressions attaching an object to an updatable string of text
  • attaching an object to an updatable string of text
    Posted by Ted Gore on February 18, 2010 at 8:58 pm
    Hello
    I’m trying to attach an object to the left side of a string of right justified text. The goal is for the text to be editable, while having the object continually update it’s position as the string grows or shrinks.
    I have no idea where to start because I can’t seem to find any data on that end of the text string.
    Any ideas?
    Cameron Pinegar replied 9 years ago 7 Members · 38 Replies
  • 38 Replies
  • Dan Ebberts
    February 18, 2010 at 11:15 pm
    Here’s a hack that should keep your layer lined up with the left edge of the text layer:
    L = thisComp.layer(“Your Text Layer”);
    for (i = 0; i <= thisComp.width; i++){ temp = L.sampleImage([i,thisComp.height/2],[0.5,thisComp.height/2],true,time); if (temp[3] > 0) break;
    [i,value[1]]
    Dan
  • Ted Gore
    February 18, 2010 at 11:23 pm
    thanks Dan,
    My expression knowledge is limited. Would this go into the position expression field for my object?
  • Ted Gore
    February 18, 2010 at 11:35 pm
    thanks dan!
    Sorry, my expression knowledge is limited, but am I putting this into the position expression field for the object?
    thanks
  • Dan Ebberts
    February 19, 2010 at 2:12 am
    Yes. The object will keep its own y position but the x should track the left edge of the text.
    Dan
  • Andre Isaac
    May 17, 2010 at 2:52 am
    Hi Dan-
    I love this expression… it’s almost exactly what I need.
    Please excuse my ignorance; how could I tweak this to attach a layer to the RIGHT side of a LEFT justified text string? I’ve tried changing some the code elements but I can’t get the result I’m looking for.
    -Andre
  • Dan Ebberts
    May 17, 2010 at 5:16 am
    I think this is the change you need to make:
    for (i = thisComp.width; i >= 0; i–){
    [i,value[1]]
    Dan
  • Andre Isaac
    May 17, 2010 at 8:00 pm
    Perfect. Thanks so much Dan!
  • Andre Isaac
    October 21, 2010 at 4:42 am
    Another question about this script: I’ve noticed that the position of an object (the one linked to the end of a text-string) changes in sync with the position of said text-string. Is there a way to link this object to a specific position (or anchor) keyframe, so that it retains its position before/after the text-string’s position value changes?
    left side
    L = thisComp.layer("");
    for (i = thisComp.width; i >= 0; i--){
    [i,value[1]]
  • Dan Ebberts
    October 21, 2010 at 4:40 pm
    One way is to just change the last parameter for sampleImage() from “time” to the specific time you want to do the sampling (0, for example).
    Dan
  • Andre Isaac
    October 21, 2010 at 8:30 pm
    That’s great! So simple… Thank you so much!
Page 1 of 4
