Attaching a wireless mic to HPX-500
I am shooting a Discovery HD project next month using the HPX-500. I have to use two wireless mics for the project. The mics are a Sony WRR-855 mounted in a BTA-801 case. It will power off the camera. The second one is a WRR-820 That I will try and mount to the BTA-801 case. I will be moving through trees and brush so velcro is not ideal. I need a more secure mounting solution. Also the camea has the IDX V-lock battery plate attached. Any suggestions?
Jeff
