Activity Forums Maxon Cinema 4D Attaching a softbody to a rigid body and then animate the rigid body
  • Attaching a softbody to a rigid body and then animate the rigid body
    Posted by Sven i. Nilsen on May 14, 2012 at 6:57 pm
    Hi, I am rather new Cinema 4D, and have just purchased Studio R13. I have used daz Carrara a lot the latest years, and of course expect that C4D can do all Carrara can, plus a lot more 🙂
    Please note: This is NOT about the cloth tag in Cinema. It is about the softbody tag.
    What I want is to attach the softbody to two rigid objects, and animate these objects. In my case, a softbody connected to two “sticks”. I have been adviced to use “connectors” for this. But I just can’t get connectors to work, they make the softbody slip and slide back and forth. Can you point me in the right direction?
    Here is an animation I have made, this video shows what I can make in daz Carrara, which I currently can not do in Cinema 4D R13 Studio:
    https://www.youtube.com/watch?v=x70mKxQ6b4k
    Here is another animation, made in Cinema 4D. This describes what I am after, I want to attach the softbody to the “sticks” / “poles”, btu have found no way to do it:
    https://www.youtube.com/watch?v=5oZCsoxvFNk
    Thanks in advance
    – Sven I
    Sven i. Nilsen replied 14 years, 3 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 15, 2012 at 5:18 am
    Here’s a sample scene: 4140_connectsoftrigid.c4d.zip
    But you’ll have to do without the artifacts and glitches from Carrara. 😉
  • Sven i. Nilsen
    May 24, 2012 at 10:33 am
    Hi Adam,
    thenks a lot for this! Sorry about the delay, I’ve been out of office for a week. Yes, it works! But still it does not, if I must say so.. I am having real problems using connectors to connect softbodies to rigid objects. In fact, I wrote Maxon Support, and they say it is not possible, they tell me to use the cloth. But the cloth does not respond to rigid objects, so that is no solution..
    I have a video here, explaining my issues. I am not a native English speaker, but hopefully you will understand most of it:
    https://www.youtube.com/watch?v=4JWptHSHzA0
    -Ingvar
