Activity Forums Maxon Cinema 4D Attaching a Connector to an Endpoint in Spline Dynamics
  • Attaching a Connector to an Endpoint in Spline Dynamics
    Posted by Eric Fitzgerald on October 24, 2013 at 6:57 pm
    Hello All,
    I’ve attached a ball and socket connector to the end of a spline being affected by spline dynamics but the connector stays in the initial position. Any way to get that connector to move based on spline dynamics?
    I’ve also tried using a constraint but the spline doesn’t pull on the object attached. The ball and socket connector has the right dynamics it just stays in the initial position and doesn’t move with the end of the spline. Am I missing something?
    TIA
    Eric Fitzgerald
    Eric Fitzgerald replied 12 years, 10 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 24, 2013 at 7:16 pm
    There is no connection between spline dynamics, which is part of the Hair system, and the regular dynamics system … unfortunately. If you want to use the two together it requires some fakery.
  • Eric Fitzgerald
    October 24, 2013 at 7:51 pm
    Thanks Adam. That helps even if it is not what I wanted to hear. At least I will not keep searching for that solution.
