Activity › Forums › Adobe After Effects › attach tracker to a mask?
  • attach tracker to a mask?
    Posted by Aaron Neitz on June 22, 2007 at 6:04 pm
    How do I attack tracker data to a Mask? this is something I always do in Shake, and can’t figure it out in AE. Haven’t found anything in the help files either
    thanks in advance!
    Aaron Neitz replied 19 years, 3 months ago 3 Members · 4 Replies
  • Peter O’connell
    June 22, 2007 at 10:47 pm
    HI, make an expression between the tracker attach point and the position property of the layer that the mask is on. Always mask on a solid layer not a footage layer.
    Good Luck
    Pete O’Connell
    http://www.barxseven.com
  • Mike Clasby
    June 23, 2007 at 1:12 am
    Yep, with Da Script:
    https://del.icio.us/escruz/Rotoscope
    It was written for Roto, but will attach mask vertices to trackers for any purpose. It works as good as the track.
  • Peter O’connell
    June 25, 2007 at 1:44 pm
    CharlieX, do you want to attach a tracker to a whole mask or to a mask vertex only?
  • Aaron Neitz
    June 26, 2007 at 6:55 pm
    Thanks guys, figured it out. I wanted to track the whole mask – I have a television set I’m putting footage into. I’ve started using solids with the mask layer and using those as my stencil….works more like I wanted it to.
