Activity Forums Adobe After Effects Attach Null Object to Each vertex point of my Mask
  • Attach Null Object to Each vertex point of my Mask
    Posted by Allen Joaquin on October 29, 2012 at 12:36 pm
    Hi, well my question is if there is any way by script/expresion whatsoever. to Add a null object to each vertex point of a mask path?
    Basicly what i wanna do is the following.
    I’ve got a mask of someone out of a background so i’ve got 2 layers, The Background and the Mask of that person.
    Now i’d like to add light point to each vertex of my mask path so then later i could add plexus into it and it would make the plexus path guided by the lines.
    So then later i could also change the points of Plexus (white points) to be the optical Flares tracked to the line points.
    Put it simply: “Is there any way i could track a path vertex point to a null object”
    Thank you.
    Allen Joaquin replied 13 years, 6 months ago 2 Members · 5 Replies
