Activity Forums Maxon Cinema 4D Attach MoSpline onto geometry
  • Attach MoSpline onto geometry
    Posted by Olly Starkey on September 22, 2019 at 4:06 pm
    Hey all
    I would like to attach a mospline to the contours of wall.
    The wall isn’t flat, it has a additional geometry for doorways, recesses etc…
    And I would like the MoSpline to ‘wrap’ around the geometry and then use the fields system to ‘pull’ the mospline away from the wall in certain patches.
    Is this possible, or is there a better way to do it? I really like the animation possibilities with MoSpline but not sure if it’s the best way to go.
    Thanks in advance.
    Olly
    Olly Starkey replied 6 years, 12 months ago 2 Members · 2 Replies
  • Brian Jones
    September 23, 2019 at 2:53 am
    maybe do a Knife along the wall where you want the spline to be, that would follow the shape perfectly, the do an Edge to Spline with that cut and use the resultant spline to feed a MoSpline
  • Olly Starkey
    September 29, 2019 at 7:13 pm
    Thanks Brian, I’ll give this a go.
    I think client has decided on a different path, but I’ll have a play with this route out of interest anyway.
    Thanks again.
    Olly
