Attach depth of field control to slider to expression
Hi
Anyone knows how to attach depth of field control to slider in expression which generates automatically when “Link Focus Distance to Layer” is pressed. I want to have more control in depth of field.
Expression goes like this:
var usingLegacyEngine = !!$.version;
try{
thisLayer( “ADBE Transform Group” )( “ADBE Anchor Point” ).value;
}catch(err){
var quote = String.fromCharCode(34);
if ( usingLegacyEngine ) {
$.error = “” + quote + “Camera 1″ + quote + ” cannot be a One-Node camera”;
} else {
throw “” + quote + “Camera 1″ + quote + ” cannot be a One-Node camera”;
var targetLayer = thisComp.layer(“Camera Target and Controller”);
try{
targetLayer.transform.position[2]
}catch(err){
$.error = “” + quote + “Camera Target” + quote + ” cannot be a 2D layer. The Focus Distance of ” + quote + “Camera 1″ + quote + ” can only be set to follow 3D layers.”;
} else {
throw “” + quote + “Camera Target” + quote + ” cannot be a 2D layer. The Focus Distance of ” + quote + “Camera 1″ + quote + ” can only be set to follow 3D layers.”;
var cameraPosition = [transform.position[0] * thisComp.pixelAspect, transform.position[1], transform.position[2]];
var cameraPoi = [transform.pointOfInterest[0] * thisComp.pixelAspect, transform.pointOfInterest[1], transform.pointOfInterest[2]];
if ( thisLayer.hasParent ){
cameraPosition = thisLayer.parent.toWorld( cameraPosition );
cameraPoi = thisLayer.parent.toWorld( cameraPoi );
var targetPosition = [targetLayer.transform.position[0] * thisComp.pixelAspect, targetLayer.transform.position[1], targetLayer.transform.position[2]];
if ( targetLayer.hasParent ){
targetPosition = targetLayer.parent.toWorld( targetLayer.transform.position );
var cameraVector = sub( cameraPoi, cameraPosition );
if( length( cameraVector ) != 0 ) {
cameraVector = normalize( cameraVector );
var targetVector = sub( targetPosition, cameraPosition );
dot( targetVector, cameraVector );
Thanks in advance
