Activity Forums Adobe After Effects Attach an object to a corner of a layer
  • Attach an object to a corner of a layer
    Posted by Maria celina Boa nova on September 10, 2014 at 6:47 pm
    Hey guys. Really need a hand here.
    I’m trying to do something like this (at 11 second)
    https://vimeo.com/73999574
    A map layer is revealed (a believe it’s made with mask and alpha matte). But here is the problem: There is 2 crosses attached to the corners of the square (that is revealing the map). How do u think they did this?
    I’m using this script Connect_Point_to_Mask_Vertex.jsx (https://www.crgreen.com/aescripts/ie/) – it puts a lot of keyframes in position property of my cross layer, but i wonder if there is a way with no keyframes, maybe some expression… cause i’m not having the proper control of my needs. Maybe i’m missing something.
    Thanks for reading.
    Maria Celina Boa Nova
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Maria celina Boa nova replied 11 years, 12 months ago 2 Members · 6 Replies
