Activity Forums Adobe After Effects Expressions Attach a mask’s path (position) to a Point Control
  • Attach a mask’s path (position) to a Point Control
    Posted by Brent Pierce on October 25, 2012 at 4:35 am
    I’m trying to drive the position of a layer’s mask via a Point Control. Simply pick whipping obviously doesn’t work.
    Anyone know how to achieve this? Could you also attach the size of a mask to a slider?
    “For I know the plans I have for you,” declares the Lord, “plans to prosper you and not to harm you, plans to give you hope and a future.”
    -Jeremiah 29:11
    Dan Ebberts
    replied 13 years, 11 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    October 25, 2012 at 5:39 am
    Expressions don’t have much access to mask data. You can link two paths together and you can use valueAtTime() on a path, but that’s about it.
    Scripts have access to everything, but of course they’re not live. You might want to check out TrackerViz at aescripts and see if that will do what you need.
    Dan
