Activity Forums Maxon Cinema 4D Atom Array (or something similar) Self Generation?
  • Atom Array (or something similar) Self Generation?
    Posted by Stephen Turcotte on January 8, 2013 at 12:39 pm
    Does anyone know how to have an object (as pictured below) self generate? I’ve created an animation where I have 2 Cloner objects- a sphere in Object Mode set to vertex, and a cylinder in Object Mode set to edge. This allows me to scale and reveal them, everything works fine. But I’m looking for an effect that can occur more randomly – Maybe build from top to bottom- and have the cylinders be emitted from the spheres of each vertex, rather than scale up from their center point.
    Any ideas?
    Thanks.
    Luke Howell replied 10 years, 3 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    January 8, 2013 at 4:50 pm
    You can use mograph to grow the pipes from the ends if you use an effector to do the scaling instead of the cloner itself. Effectors honor the cloned objects’ axis position.
    Example: 5177_atomtypearraygrowfromends.c4d.zip
  • Stephen Turcotte
    January 8, 2013 at 5:56 pm
    Good point, and good to know. Thanks for the sample file- very helpful!
  • Luke Howell
    June 14, 2016 at 4:17 pm
    Hey Adam,
    I’m after a similar animation to the one you kindly provided in your scene file.
    I want to have more control over the indivial edges and have them grow one after the other (not all at once), what would be the best way to achieve this?
    Thanks.
