Activity › Forums › DaVinci Resolve › ATI Radeon HD 5870 & Resolve — Monitoring problem
  • ATI Radeon HD 5870 & Resolve — Monitoring problem
    Posted by Joana Rodrigues on November 14, 2013 at 9:23 pm
    Hi everyone,
    A little disclosure: I’m far from being an specialist in graphic cards, so please forgive any misunderstanding on my part.
    I’m new to DaVinci Resolve though I used to work with Apple Color. So after downloading the new Resolve 10 Lite, I tried to properly connect that to a external monitor. This is the one: https://www.lcdracks.com/racks/IMD/V-R201-IMD-TE.php
    It worked wonderfully with Color (and Avid and FCP7, for that mater), but I can’t figure out why it’s not working with Resolve. Here’s is my graphic card: ATI Radeon HD 5870 1024 MB
    And here’s my setup:
    MacPro
    Processor 2 x 2.4 GHz 6-Core Intel Xeon
    Memory 12 GB 1333 MHz DDR3 ECC
    On Media Composer settings, I chose the right Video Format:
    1080p 23.96
    YUV 4:2:2 SDI
    Video Levels
    (and I tried to change theses to see if I could gete something, but no..)
    On Resolve Preferences >
    Video I/O
    For capture and Playback > None (Only option)
    For Resolve live users > None (only Option
    ps: No red rocket available
    I really don’t know what’s wrong. Do I need another graphic card? Do I need any blackmagic hardware?
    Any Ideas? All help is welcome!!
    Thanks a lot guys!
    John Fishback replied 12 years, 10 months ago 4 Members · 5 Replies
  • Peter Chamberlain
    November 14, 2013 at 10:57 pm
    Hi. Have a look at the published config guides located at the top of Bmd post production forum. I looks like your system is not quite correct for use with resolve.
    Peter
  • Rohit Gupta
    November 14, 2013 at 11:34 pm
    You need a Decklink I/O card!
  • Joana Rodrigues
    November 15, 2013 at 7:18 pm
    Thanks, Im gonna double check that.
  • Joana Rodrigues
    November 15, 2013 at 7:20 pm
    Hi, thanks for the reply!
    Is there any other way or card that I could use for monitoring? If the Decklink is the way to go, would the DeckLink Mini Monitor do?
  • John Fishback
    November 20, 2013 at 5:48 pm
    We’re in the same boat as we have AJA IOs. Resolve only works with Blackmagic IOs. There are a bunch of them and some are relatively inexpensive.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
