Activity Forums Blackmagic Design ATEM Switcher Power
  • Doug Fish
    December 8, 2011 at 11:50 pm
    It’s dead, Jim.
    The good news is it should still be under warranty.
  • Jason Slenker
    December 11, 2011 at 2:18 pm
    If you have the switcher and the control panel you can switch the power supplies between the two units. This can help you trounleshoot the issue. If you have absolutely no lights or anything ( on the control panel) the power supply is probably the issue.
    Jason Slenker
    Senior Engineer
    JPL
