Activity Forums Blackmagic Design ATEM 1 M/E Production Switcher Questions
  • ATEM 1 M/E Production Switcher Questions
    Posted by Jon Charity on August 18, 2011 at 7:54 pm
    Hello all,
    I had a few questions regarding the new Black Magic Design ATEM 1 M/E Production Switcher. I read the review that Bob Zelin posted earlier this summer and the unit does seem quite impressive. The low cost combined with the feature set is sure to make it a front runner. I do have a few concerns though.
    First, the inability to scale different HD formats requiring all input formats be the same. Quite often I have to mix various HD sources from a variety of different devices and the ability to “mix and match” would be priceless. Is this a limitation of the hardware or is it a feature that could be later added via software update?
    Secondly, I question the limited set of supported HD formats and frame rates. 1080i50, 1080i59.94, 720p50, 720p59.94 covers but a few of the HD signals I would need an HD production switcher to support. I know 1080PsF frame rates are not normal for studio cameras to output but the capability to handle 1080PsF23.98, 1080PsF24, 1080PsF25, 1080PsF29.97, 1080PsF30, 1080p23.98, 1080p24, 1080p25, 1080p29.97 would be absolutely necessary. Again, could these formats be added via update or are they limitations of the hardware itself?
    Tracy Peterson replied 15 years ago 3 Members · 2 Replies
  • Bob Zelin
    August 20, 2011 at 4:19 pm
    REPLY –
    REPLY – I don’t know if it will added later, but you absolutely CANNOT use different formats (like 1080i and 720p) at the same time.
    You choose 1 format – and that’s it. And what is your alternative – is there a less expensive solution for you available ?
    REPLY – again, I dont know, but I have TONS of clients who want to work at 23.98, and the ATEM series absolutely does not work at “odd” formats other than what is specified. Basically, you are going to work with 1080i 29.97, or 720p 59.94, or this is not the product for you.
    Bob Zelin
  • Tracy Peterson
    August 31, 2011 at 3:58 am
    Another option is the fairly inexpensive any in/ any out converter from Grass Valley at 1200, which gives you a scaler and converter for any of those inputs. I added one to my list with the ATEM to provide conversion and scaling for computers/game consoles and any other odd source of video that might not conform.
    Tracy Peterson
    http://www.onetwomany.com
