Activity › Forums › Blackmagic Design › ATEM 1 M/E doesn’t laptop as HDMI source
  • ATEM 1 M/E doesn’t laptop as HDMI source
    Posted by Matt Drabick on August 17, 2012 at 9:19 pm
    I setup an ATEM 1 M/E as a demo system in my shop. I am using the very same laptop that normally connects to my ATEM Television Studio. My Television Studio sees the output of my laptop as an HDMI source. When I connect the same laptop to any of the four HDMI inputs on the 1 M/E the laptop isn’t seen.
    I have connected the HDMI output from my TriCaster 855 into the 1 M/E and the 1 M/E sees the HDMI output from my TriCaster 855.
    I connected a second computer with an HDMI output and my ATEM 1 M/E didn’t see the computer as an HDMI input.
    Do I have a 1 M/E with flaky HDMI inputs or is this something else.
    I am running the ATEM 3.2 software on the host PC . . . .
    Remember, my Television Studio sees the HDMI output of my laptop using the same host computer driving the 1 M/E.
    Matt Drabick, DigiTek Systems
    Eric Harrison replied 14 years, 1 month ago 4 Members · 5 Replies
  • Eric Harrison
    August 19, 2012 at 12:24 am
    Same thing happened to me. What worked for me was to install the 3.1.2 drivers.
    If you have a mac, go to here
    If you have a PC, go to here
    I did talk to BMD support on the phone and explained that 3.2 didn’t work. I would do the same if I was you just so they know that other people are having the same issue.
  • Nathan Wright
    August 19, 2012 at 9:00 pm
    We are having the same issue on 3.2 with the hdmi on multiple units
  • Eric Harrison
    August 20, 2012 at 5:54 pm
    Just talked with BMD and they said that they have had several calls about this issues. What they said is that the switcher is looking for a 59.94fps signal but if the signal is 60 then that’s fine too. Computers use a normal rate of 60Hz for monitors. 60Hz = 60fps. But with this new update that tolerance is tighter to where the 60Hz not’s match. They are working on trying to fix it.
  • Liam Kennedy
    August 21, 2012 at 7:13 am
    That is welcome news to hear BM recognizes the issues (I’ve reported the issues… but not received a reply).
    This is a BIG issue for many of us I think. The 3.2 Firmware has effectively broken all of the scalers/converters I use to bring various devices in to my ATEM 1ME. No longer functioning are my Altona VGA to HDMI, Gefen Toolbox HDMI Scaler, Apple TV (3rd Gen).
    I also have a TVS… and the 3.2 firmware did not break the HDMI compatibility.
    I do hope they fix this soon.
  • Eric Harrison
    August 22, 2012 at 5:38 am
    Got an email from BMD saying that they now have their own Forum. Here’s the link
    https://forum.blackmagicdesign.com
