Activity › Forums › Adobe After Effects › Async in AE extendscript?
  • Async in AE extendscript?
    Posted by Dan Berger on May 20, 2020 at 4:28 pm
    Hello,
    Is there a way to execute commands asynchronously in AE extendscript ?
    Something like the normal javascripts async function(){……} ?
    I’m trying to execute multiple instances of aerender.exe using the System.callSystem() function.
    Is it possible to run System.callSystem() asynchronously?
    Dan
    Breton Brander replied 2 years, 9 months ago 3 Members · 2 Replies
  • Andrew Roberts
    May 27, 2020 at 4:01 pm
    Not within the Extendscript code itself, but all calls to execute ES through an Adobe CEP panel are asynchronous and can have a callback function that executes when the ES is done.
    https://github.com/Adobe-CEP
  • Breton Brander
    December 1, 2023 at 6:35 pm
    Hi Dan,
    I believe you can accomplish what you’re hoping for like this:
    Solution 1:
    The solution below runs a command and does not wait for the result to return. Instead it outputs the result to a text file on your desktop.
    var command = ‘echo “Hello world!”‘
    var outputFile = “~/Desktop/output.txt”;
    system.callSystem(‘nohup ‘ + command + ‘ > ‘ + outputFile + ‘ 2>&1 &’)
    Solution 2:
    The solution below runs a command and does not wait for the result to return. The result goes nowhere so you won’t know how the command resolved.
    var command = ‘echo “Hello world!”‘;
    system.callSystem(‘nohup ‘ + command + ‘ > /dev/null 2>&1 &’)
    Source: https://wordpress.com/post/bretonbrander.wordpress.com/3548
    (I share similar ExtendScript solutions at the website linked above too)
