Activity › Forums › Adobe Premiere Pro › Asus P5WDG2-WS MB problems with adobe Prem Pro 2
  • Asus P5WDG2-WS MB problems with adobe Prem Pro 2
    Posted by Videoguys Australia on July 12, 2006 at 8:18 am
    Hi Guys,
    We are experience the strangest results I have ever encountered. Every time we open Adobe Prem Pro 2 the machine restarts!!
    We have changes the board, Memory; all hardware
    Igor Babic replied 20 years, 2 months ago 3 Members · 2 Replies
  • Tim Bond
    July 13, 2006 at 7:41 pm
    if you google windows BSOD there are several issues that can cause this. If it won’t much past the bios / post screen then it’s most likely a memory issue. Swap out the memory and see if you have the same problem, it could be processor or motherboard but it’s most commonly memory. If you’re getting BSOD booting into windows but can boot into safe mode then it’s probably a driver conflict. Also do the basics and check that everything is plugged in and seated properly. Cables, boards etc. Is it BSOD in the same place in the boot up process each time?
    Tim
  • Igor Babic
    July 15, 2006 at 9:02 pm
    Update MB bios. New machines from Asus often come with old bios. Old bios of that motherboard is not Dual core compatible! System disk and install boot CD rom disk if they are PATA they must be on non raided ATA port for proper win xp install and boot. Also as previous stated check your ram modules (put them in non paired slots maybe). I hope this helps. If somebody tells me this before I have install my Dualcore on P5WD2 it saves me 12 hours of useless instalation and swaping staff in my machine to solve conflicts that dont exists…Happy tweaking
