Activity Forums Maxon Cinema 4D Assistance needed with lagging viewports
  • Assistance needed with lagging viewports
    Posted by Marten Kopp on June 21, 2011 at 11:34 am
    I recently both a new PC with the following specs:
    Intel Core i7 X 990 3.47GHz
    2x AMD Radeon HD 6900 Series
    24 GB DDR3
    Software is all installed at SSD
    But now I am running C4D R12 and the weird thing happens. When I add a cube (or some other primitive object) it starts lagging as soon as I select the object and try to adjust the settings or just simply move around the camera.
    If I make the object editable it all gets back to normal.
    Someone knows the problem causing this issue? I already figured out when I deactivate OpenGL it all gets back to normal.
    Tim Shetz replied 15 years, 3 months ago 2 Members · 2 Replies
  • Marten Kopp
    June 27, 2011 at 10:30 am
    No one?
  • Tim Shetz
    June 27, 2011 at 10:16 pm
    I guess I figured you had answered your own question:
    Seems like openGL is the problem. You could make sure your Video card drivers are up to date.
    __________
    Tim Shetz
    c4dtraining.com
