assign group of textures to group of objects?
Hi hello help! I’m working on a visualisation in C4D similar to this cluster / cloner effect [https://www.youtube.com/watch?v=jl6JZSfkLwk&t=33s%5D.
I have about 2000 objects in the cluster made up of cones, spheres and cubes, and want each individual object to have a different texture (I have a folder of specific images, one image for every object).I loaded the first 250 textures ‘by hand’ by creating a new material and loading an image to each – because I couldn’t find a way of importing the entire folder of images? If there’s a way to create a folder / library of textures from my existing images and upload them all at once – that would be GREAT.
Secondly, now I have made a layer with my first 250 textures, I want to apply these to only the cones. I have all the cones in one layer / one group but when I drag the textures to the cone group, it assigns ALL of the textures to ALL of the cones. Is there a way to apply one material to each cone? It doesn’t matter which cone receives which texture, so assigning one ‘random’ material from my texture group / folder to each object would also work for me.
I think this tutorial achieves what I need – but I don’t speak Russian. [https://www.youtube.com/watch?v=I2JSTe4ED9Y&t=14s%5D I’m also a beginner with c4d and coding – so the simpler solution the better! Any help asap would be amazing
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
