Activity › Forums › Maxon Cinema 4D › Assign a displacer deformer only to a polygon selection
  • Assign a displacer deformer only to a polygon selection
    Posted by Tulio Laanen on April 12, 2019 at 12:39 pm
    Is there a way to assign a displacer deformer only to a polygon selection, instead of a whole object?
    Maybe a silly question but I cannot figure it out.
    Tulio Laanen replied 7 years, 5 months ago 2 Members · 2 Replies
  • Brian Jones
    April 12, 2019 at 3:56 pm
    yes, you can make a Selection tag of the face polys you want to use then add a Restriction tag to the Displacer deformer and drag the selection tag into that.
    you could also use displacement in a material by stacking the materials and limiting the material using displacement with a selection tag. This would render slower if you use Sub-poly displacement but you get to use sub-poly displacement, so much more detailed displacement and you don’t see the displacement until render.
  • Tulio Laanen
    April 12, 2019 at 6:27 pm
    oh yes, that sounds pretty straight forward.
    Two great tips! thanks, I appreciate the help!
