Activity › Forums › Adobe After Effects › Asset size motion track?
  • Asset size motion track?
    Posted by ed sparks on October 17, 2022 at 7:57 pm
    I motion tracked a broken window at the top of the arc. That was very easy. But when I used the same motion track to replace the house instead of the window. it was a tik tokker. So my theory is…
    should i enlarge the squares as large as the asset im working with?
    because that was like 4 seconds for all night? I canceled it and went smaller… a few burps… i could’ve cycled frames but i get bored. i am assuming that is correct. because the house was in the establishing shot.
    If you want to burn 1.5 on it here is my reel. its the last part.
    https://youtu.be/x1NL_CTC0xE
    Graham Quince replied 3 years, 11 months ago 2 Members · 1 Reply
  • Graham Quince
    October 22, 2022 at 12:12 pm
    I’m sorry, I’m not sure what you’re asking. Are you saying it took all night to render a 4-second shot?
    The show being a still of a house tracked to a video. If that’s the case then yeah, it should take that long, but without seeing your whole composition, it is quite hard to take a guess at the cause.
