Activity Forums Avid Media Composer Assertion Failed Message When Opening Script .avc file in Avid 7.0.6.1
  • Assertion Failed Message When Opening Script .avc file in Avid 7.0.6.1
    Posted by Brian Eikenberry on August 12, 2017 at 12:07 am
    I’m working on a project running Avid Media Composer 7.0.6.1 and Yosemite 10.10.5. I haven’t had any problems for the first month but this week I’ve had multiple scripts that have become corrupt while I was scripting. Avid will freeze up and when I relaunch the project the script I was working in will get me the following message:
    Assertion failed: from > lastRange.from
    [/Snapshots/relengmtnlion2_1461121310/coresw/core/Projects/Mac/../../src/lists/RangeArray.c:196]
    Multiple recent backup files in the avid attic will also give me this message when I try to revert to an older version.
    I’ve tried using different avid user settings, trashing preferences, and using a different computer (same specs) with no luck.
    Has anyone had this problem and if so do you have a solution? I’ve never had this problem before working with a computer running 10.8.5 so my best guess is that it’s related to Yosemite.
    Brian
    Brian Eikenberry replied 9 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
