First off, you can discover a clip’s properties (video [frame] size, frame rate, Compressor [the clip’s codec], etc.) by right-clicking on the clip in the Browser or Timeline and choosing Format. That’s where you’ll find important information about the clip. You are able to change some of these properties. One of them is Anamorphic. If you make a change to a clip in the Browser (click in the space to the right of Anamorphic) the change will remain every time you edit a portion of that clip into a timeline. If you make a change to a clip in the timeline, however, it will only affect that clip.
Besides changing clip’s properties, you can also change a sequence’s anamorphic property. With a seq open choose Sequence menu > Settings and you see them. Look to the right for the Anamorphic 16:9 checkbox. If it’s checked, uncheck it. That will probably fix the image in your Canvas. However, the anamorphic setting in certain clips may conflict with the seq setting and may have to be changed.
Play with it and see how it works. This is one of those reasons for converting all formats you receive for an edit to just one format, so the settings are consistent clip-to-clip.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
