Activity › Forums › Adobe Premiere Pro › Aspect Ratios…
  • Aspect Ratios…
    Posted by Roderick Salter on April 14, 2018 at 12:43 pm
    I am a beginner and my question may be completely dumb and sorry if that is the case.
    So I don’t waste money buying the wrong editing package, I need help determining if I can import into Premiere Pro a video clip shot in 16:9 and some how change or export it as a clip in 16:10 aspect ratio.
    Now that said, I tried to do this using a trial version of Premiere Pro and I “think” I was successful. Unfortunately, the trial version had expired (was only for 7 days) before I got to re-test my approach. I think I put the clip into the bin where I was able to crop the ends to get the 16:10 aspect ratio and then placed it in the time line and exported it where it remained as a 16:10 clip.
    Why I would like to do this is because at my church we typically get 16:9 video clips to show on occasions but, the new projection system runs 2 Epson WUXGA projectors and 2 16:10 screens. I recently installed this system as I much prefer the 16:10 aspect ratio (just a personal preference). Also, we use Power Point extensively with the 16:10 format. Having the ability to project the clips so they are 16:10 means the screens are completely filled without black bars at the top and bottom of the picture. I appreciate that 16:10 will necessarily crop about 5% off each end of the 16:9 image format however, that in the majority of cases is acceptable as little meaningful information will be lost.
    I would be grateful if anyone can assure me that what I want to achieve can be done with Premiere Pro. Even if my way works there may be a better way to do it.
    Rod
    Roderick Salter replied 8 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Roderick Salter
    April 14, 2018 at 11:39 pm
    Thanks Dave for your reply to my question.
    Yes you are correct, 16:10 is not a standard motion picture format. But for the few occasions I need 16:10 then I am prepared to wear the extra hardships that it encounters. That said, I still would like some guidance about how is the best way to do it with Premiere Pro assuming of course that it is possible and that my original attempt was a valid one.
    Rod
  • Chris Wright
    April 16, 2018 at 4:04 am
    you will have to select square pixels in the ratio of 1.6. for example, 1440/900=1.6
  • Roderick Salter
    April 16, 2018 at 4:13 am
    Thanks Chris.
    In my trial version, now expired, I believe I did that but doesn’t hurt to be reminded.
    ROd
  • Chris Wright
    April 16, 2018 at 5:25 am
    resolve is free up to resolutions UHD.
    or hitfilm is free too.
  • Roderick Salter
    April 16, 2018 at 6:52 am
    Thanks Chris for these suggestion. I will look into it.
    Rod
  • Todd Perchert
    April 16, 2018 at 4:57 pm
    Rod – have you thought about using something better than Powerpoint? Like ProPresenter? I believe you can set it up to crop the 16:9 video the way you need. And you can import your PowerPoint presentations into it. I’ve used it at my church.
    TC
  • Roderick Salter
    April 16, 2018 at 10:55 pm
    Thanks Todd,
    No, I hadn’t thought about using something like Pro Presenter but it may be an effective way to address the issue that I have. Thanks for your “thinking out side the box” approach. I will investigate that software and take it from there. There may be some other benefits from using it as well.
    Rod
