Activity › Forums › Apple Final Cut Pro Legacy › Aspect ratio question
  • Aspect ratio question
    Posted by Lee Mceachern on March 11, 2007 at 10:49 pm
    Hi. I have experience in a few other edit systems but I’ve only recently — belatedly — begun working in Final Cut Pro. My question concerns what sequence setting I should use for my current project. It’s a 3-4 minute piece composed entirely of still images and music. (I’m using Pan Zoom Pro for the stills.) The deliverable is a 16×9 digital file that will be projected. In the sequence settings dialog I selected HD 960×720 and the compressor DVCPRO HD 720p60. Does that sound reasonable? Will that allow me to create an appropriate deliverable?
    Thanks for any guidance.
    Lee
    Steven Lambion replied 19 years, 6 months ago 2 Members · 1 Reply
  • Steven Lambion
    March 15, 2007 at 7:24 am
    That sounds reasonable to me. Just a little thing if your not using a preset to adjust the sequence, make sure field domination is set to none, but you probably already know that.
