Activity › Forums › Adobe Premiere Pro › Aspect ratio puzzle
  • Aspect ratio puzzle
    Posted by Donnerb on October 31, 2007 at 6:14 pm
    I am using Pro 3.0. When I try to export 4:3 video clips, they are slightly too narrow, leaving vertical black bars on each side. The depth is fine (480).
    The only way I can get the clips to be wide enough (720×480), is to export them at an aspect ratio of 0.9. However, this slightly stretches the clip horizontally.
    I have tried several different combinations and this is what it comes down to.
    I need the clips to be exactly 720×480 because a colleague needs to import them into Final Cut for a documentary we’re making and we need the clip dimensions to match.
    Help, please.
    Kathy
    Scot Sheely replied 18 years, 11 months ago 4 Members · 3 Replies
  • Blast1
    October 31, 2007 at 6:01 pm
    [donnerb] “The only way I can get the clips to be wide enough (720×480), is to export them at an aspect ratio of 0.9.”
    640×480 with square pixels is 4:3, (.9) is the proper pixel aspect for DV(720×480) 4:3, what sources is your footage composed of??
  • Mike Velte
    November 1, 2007 at 9:59 am
    Are you in a NTSC DV 4:3 project? (Project settings).
  • Scot Sheely
    November 3, 2007 at 1:51 pm
    Seems to me like you created a 16:9 (1.2 pixel aspect ratio) project.
    Try closing that current project and create a new 4:3 project. That will give you the proper pixel aspect ratio (.9) for video shot in 4:3.
    You shouldn’t have to stretch it at that point at all.
