Activity Forums Adobe Premiere Pro Aspect ratio problems when going from Premiere to Quicktime
  • Aspect ratio problems when going from Premiere to Quicktime
    Posted by Jamie on January 10, 2007 at 7:29 pm
    Hello everyone,
    I am preparing the monthly podcast for our charity called OneWorldTV. Its the first one that has been filmed on DVCAM in 16:9. I have exported the final cut and then brought it into quicktime so that i can export to .m4v format, so that it can then be fed through i-tunes for ipod format.
    The only problem is when i try and play the outputted avi from Premiere, quicktime does not keep the aspect ratio. It squashes it to 4:3, highly annoying. I have tried exporting out as a .mov file and it still squashes the footage.
    Does anyone know of any way to stop this happening, I really need it to preserve the aspect ratio.
    Many thanks in advance,
    Jamie
    Jamie replied 19 years, 8 months ago 1 Member · 1 Reply
  • Jamie
    January 11, 2007 at 12:31 pm
    Hi everyone
    I think i figured it out. If i export as square pixels but still with 16:9 ratio everything seems to be fine.
    Thanks anyway.
    Jamie
